1 - 20 of 26 Posts
Hi,
I'm considering installing hardwood or engineered wood floors. I'll be installing them on the 2nd floor of my house. They will go over the entire floor, except the bathroom (but including the closet).
I've attached a floor plan.
My question is, where should I start? I'd be inclined to start in the hallway, since it makes (to me) most sense for the floor to be parallel to that wall (it highly visible). If the floor is slightly out-of-parallel in the bedrooms and closet, nobody will every notice (covered by clothes or furniture.
Any thoughts?
-Steve
the Musigician
for me, i'd go with hardwood, not engineered.
and as to where to start, i guess it'd depend on how you plan to run the flooring, all N to S? or all diagonal? or hallway NtoS and rooms EtoW?
DM
Good point, I didn't mention directions. I'd never thought about changing the plank directions. I'll have to consider that.
With the floorplan I attached, the planks would run vertically (NtoS as you put it). The floor joists run horizontally (EtoW).
I'd be concerned having the wood fun parallel with the floor joists in the two rooms if I did those horizontally.
-Steve
(Just in case it matters: The top of the floorplan is actually east, the leftside is north. There can be a fair amount of sun at various times of the day from the windows.)
Hi,
Right now there is carpet. Under the carpet is a 3/4" plywood subfloor. I'll obviously remove the carpet, and I plan to add some screws to the subfloor (original install was nails, and there is some squeaks). I don't want to add more subfloor if I don't have to.
I'm not positive the joist spacing is, but it's most likely 16"
I'm using hardwood and engineered as shortform for solid hardwood, and engineered hardwood. I'd prefer the later, but will take the former. In either case it will be prefinished planks (likely between 3 1/4 and 6 inch widths). Right now I'm leaning towards a walnut engineered click lock (which I would nail down anyway) or a woven bamboo stand solid T&G.
Banned
still need advice ?
If you havent done your install yet. email me for advice..
[email protected]
Hi,
Any thoughts?
-Steve
Still Learning
Does this have something to do with many people I hear mentioning running the hardwood vertical to a primary light source? I never heard that until laminate floors became popular. With laminate, those wider plank floors really do show the seams and it can really stick out. With hardwood floors it's not as noticeable...and I never heard the suggestion before laminate floors came into being.
Banned
Bathroom floor
You don't need a subfloor under Hardwood, laminate or engineered wood flooring. You only need a subfloor under Ceramic or vinyl flooring. in the case of Ceramic, its a cement based board. for vinyl you only need a 1/4 inch subfloor which has nothing to do with material support. its so there's a smooth surface because vinyl will show ALL improfections that might be under it....
Hi,
The word your looking for David is UNDERLAYMENT.
Subfloor is what is installed over floor joists. You do need that for wood.
I know you know this....just wanted to point out the word for the wood that is over the subfloor.
Banned
see here.
Wow. your enjoying yourself arent you ?
Does it make you feel smart ? to twist what i said. Sure who doesnt know you need a SUBFLOOR under hardwood.. I used the word subfloor for the laymen installers... and the DO IT YOURSELFERS.. hence the acronym DIY.
thank you for belittleing everything i said to make yourself appear to be the all knowing floor WIZ of all time... have a great day . I wont come back here to get attacked by ppl like you... you nit-picked everything i said.... If you can't see that cushioned vinyl isnt as good and solid vinyl flooring. then your a disgrace to the industry... you almost sound like a salesman.. not an installer... shakes my head ... SteveSmith98 you buy whatever you feel works for ya. when it rips... don't call me to fix it... good luck.
Banned
Super Moderator POWER TRIPPIN
Oh i see... your the all knowing "Super Moderator"
just like ive said a 1000 times in my life.
give a janitor a clip board and his head swells at the thought of being THE BOSS... the proof is your nit-picking apart what i said to SOMEONE ELSE.
Sure inlay can rip too. so can steel if you hit it hard enough..
the FACT IS.. what is better. and all installers know that cushion vinyl floor does not hold up like Inlay does. period..
Steve. go to your local flooring store or a flooring supply house that has installers loading up in the morning.. and ask them all. 99% will say.. cushion floors suck. A salesman wont say that.. they wouldnt sell half the materials the offer if they told the truth.. LOL
good luck steve. I hope whatever you pick works for you.
Wow.
Well not a problem.
If you like to help then so be it.
I get nit picked all the time. It's a part of the process.
I also commend people who are very professional.
I am a Moderator on this site and I request that any further issues with me be directed to Nathan (owner of the site) or private message me.
Thank you.
the Musigician
this is nit-picking everything you said? he simply corrected your terminology.
something ALL forums could use more of! i thought his response was polite and non-insulting. perhaps you took it the wrong way?
when people use the wrong terms for things, it always leaves me wondering "what the h3ll do they mean??" i APPRECIATE when i'm told the correct thing to call something, then the next time i'm talking to someone about one, i don't come off looking like an idiot!
and abbreviations too folks, at least ONCE in the thread, please tell us DIYers what the heck you're talking about!
BHT boxes??? NYS vinyl bearings??? QPL corner shanks??? (ok, i made those up, but you get the idea.....)
DM
the Musigician
"The word your looking for David is UNDERLAYMENT."
and not to nit-pick, but it's you're, (you are) not 'your' (your word, your underlayment) and motorcycle, not mortorcycle... -=chuckle=-
but i don't want to be picky...... *GBEG*
DM
DM
Wow...your right...been there for months and months...never noticed....
I was just so pissed about season being over...but now it's back...so i will change it...
wheeehaw!
the Musigician
wheeehaw!
nononono, that should be YOU'RE right!!!! lol
and i mentioned the mortorcycle in another thread.... guess you missed it there.
DM
1 - 20 of 26 Posts
