The HVAC in my house isn't working properly and I need to figure out why. All the equipment (or whatever you want to call it) is about 24 years old.
The problem started about a month ago when the heat (heat pump) was on. I noticed that hardly any air was blowing out of the vents and the air that was blowing out was cool, not warm. Also, the lights in different rooms would dim every 4 minutes or so. I turned off the heat at this point and notified the owners of the house who happen to be my parents.
I turned on the central A/C yesterday morning and the same thing is happening. The lights (and microwave, when in use) in different rooms dim every 4 minutes or so and hardly any air is blowing out of the vents. The fan was set to "on" so everything was running nonstop for over 6 hrs, but the temperature in the house never went down. It seems to be working enough to keep it from getting really hot though.
From what I can tell, everything seems to be running. The outside unit seems to be working normally.
My father says he put in a new filter, but this was after the problem started a month ago. He mentioned that the unit might need more Freon, but since the heat doesn't work right either, I wouldn't think it would need Freon. He mentioned something about getting someone to check the pressure (whatever that means), but knowing him this could take weeks and I'm burning up.
Does anyone have any idea as to what might be wrong? And since the lights keep dimming, will that harm any of my electronic equipment, like my computer?
Some other possible relevant information is that the wiring in the house is "piggybacked" (I still don't know what that means). Before the problem started, some of the lights in the house would dim when the outside unit would come on. It seems like more lights were dimming this past winter, but I'm not sure. Additionally, several weeks after this problem originally started, I began having problems with my hallway light switches. When they're switched on/off, they kick the breaker, so we just don't use them anymore. But I noticed problems with those light switches over a year ago, so they might not be at all related to the HVAC problem. I just thought it was worth mentioning.
