Hello!
So my husband and I completely remodeled our house a few years ago, including gutting the bathrooms. We somehow got the bright idea of using hardibacker throughout the whole bathroom....ceiling, walls, etc.
We tiled the tub surround and then taped/sheetrock 90ed the seams. We then primed and painted the non-tiled walls and ceiling and it looked pretty good.
The problem is, a lot of those seams are now cracking. (Where the ceiling meets the walls and on the flat surfaces of the ceiling at taped joints as well.)
I have two thoughts on this.
Around the same time we ended up adding a major supporting beam to the house that had been missing.
Obviously, that moved some things structurally. We have had lots of new drywall cracks all over the house in the last few years, which I attribute to this movement and to a kind of hack drywall job by previous homeowners. The cracks are mainly in the ceiling/wall joints, some interior corners, and around the new support beam. So I guess I am wondering if these bathroom seam cracks are just a result of structural movement like the others.
My other thought is that the hardibacker is just not cut out to be a drywall product and therefor is causing the cracking due to its rigidity....? We did use all the appropriate tape and screws for installation.
I am actually pretty good at taping and mudding seams, and my plan is to fix all of these cracks in the next few months so that we can finally be finished.
I am REALLY worried that we screwed ourselves by using all hardibacker instead of normal green drywall like we should have. I hate seeing drywall cracks anywhere, it is just a huge pet peeve of mine.
My husband is kind of burnt out and done dealing with it so I will be hard pressed to convince him to tear it out and use green drywall if need be. But I want to fix this so that I am not taping and mudding every few years.
Please help!
Please help!
