I am trying to hang a corner cabinet above a washer (will hold laundry detergent so needs to support weight). The cabinet is 30" tall and 24" wide.
The problem I am running into is there are only 2 studs available (1 on each side) to attach the cabinet to via the top and bottom mount rails. The stud in the corner of the room is not accessible due to the flattened corner of the back of the cabinet. This is the only cabinet being mounted, no other cabinets on the side to distribute the weight.
I thought of attaching 1x4s to the studs and then attaching the cabinet to the 1x4. This would let me get 4 acrews on each wall, 2 on top mount rail and 2 on bottom mount rail.
Does anyone have any other suggestions for hanging this cabinet securely? If experience in similar situations?
Thank you.
Thank you.
