Here's the pull-up bar in question:
https://www.dickssportinggoods.com/p/ethos-pull-up-bar-19au6uthspllpbrxxeac/19au6uthspllpbrxxeac
I wanted to install above a double door. This house has always been kind of screwy with the wall studs as it is, being drywall hung over plaster and lathe. When I hung a TV I lucked out because the electrical outlet gave me a clue.
In this case, the magnetic stud finder found 3 that are 14" on center and then one that is further out at about 16." See attached photo. It wasn't going to work with the length of the backing plate for the bar. The 8 lag screws provided would only have hit 3 pairs of studs from right to left.
I ended up getting a piece of wood to use as an additional backing and bought longer lag screws (plus 2 short ones for the far left section that wasn't going to be attached to a stud. The problem is, the lower holes all seem to be hitting 2x4 but the upper holes don't seem to be. I drilled a couple of larger random holes toward the middle and am seeing a lathe piece running horizontally. Easily drilled a hole right through.
When I check on the other side of the wall the stud finder sticks exactly opposite of where my holes are drilled. There have to be studs there right? Shining a light in the holes it's hard to tell. I see some wood dust but I shouldn't be able to drive a drill bit all the way through the hole without hitting something unless the studs are not actually 2x4's up here. The drywall and plaster adds up to about an 1.5" I'd say.
Anybody with some framing knowledge that can advise? The system weighs about 30 lbs and I'm about 190 lbs. so I can't mess around with this.
Thanks in advance.
Thanks in advance.
