Hi All,
I'm moving into my first house soon and the first project on the list involves adding some support for the load bearing wall that was removed. The ceiling appears to be lath and plaster, with joists that are nailed together (huh?). The joists span from one end of the house across the width, about 6m (20') in total. I'm just guessing but it looks like the joists were nailed where the load bearing wall used to be. So needless to say there are signs of a minor sag in the ceiling.
The home inspector said to "hang a beam" in the attic and secure the joists to it, since it is only the ceiling weight being supported I will be using 2 laminated 2x10s across the span of two existing walls that are directly over the I-Beam in the basement.
The approach I think will work best is cutting a hole in the ceiling, feeding up the beam into the attic.
Here is a shot of the joists nailed together,
Any advice or comments would be awesome, here is what I'm going to do...
1. Jack up the ceiling in the area I plan to work by about 2.5-3cm (1") using some type of jack with 2x6s to spread the weight on the floor and ceiling.
2. Construct 2 temporary support walls about 1m (3') apart on both sides of the work area and hammering in the vertical 2x4s to provide some extra stiffness before toenailing them in so they don't slip.
3. Place the two 2x6s across the joists, securing them on the joists that are directly over the existing walls (or build up the wall header if the joist aren't directly overtop of the wall and attach to that)
4. Attach the joists to the 2x6s using hurricane ties with some good screws
5. Remove the support walls.
6. Slowly release the jack.
I have a couple questions.
Can I safely cut the hole through the lath and plaster without a lot of repair? I will likely put some plaster washers around the area I cut and do some serious scoring of the plaster with a utility knife first.
Is this the best way to get the beams up in the attic? The beam will be about 3m (10').
Can I walk on the joists after I have the support walls built to get across to the other end where the beam will go? The joists currently will not support my weight.
Is this going to be a killer project that I should just avoid by putting in an external header, or a flush header?
Thanks in advance. My ability to get more accurate measurements and pictures is zero until I actually move into the place. I took a week off of work to try and get this, among a few other things done right away when we get possession of the house.
-T
-T
