I have an existing slab which I'm building a shed on. I have a permit, have drilled for vertical rebar, will use horizontal rebar and am building form for an 8x8 wall just to get the wood away from ground water and snow.
So far I have dug around the slab and set 2x4s level with the slab for the outer form boards to sit on. I've cut all of the form boards and assembled with deck screws. They are 1x8 spruce. I've driven 2x2 pt spikes every 3-4 feet around the perimeter. I will shim the outer form boards to these using plywood and screw them in place. On the inner boards I will cut 45 corner braces. I will also brace from one inside to the other. Then, near these braces I will add an anti spreader board across the top and screw in place.
I've never built forms before, does the seem adequate? Any suggestions? TIA
