I just installed five of 4” led recessed lights in my hallway I had 2 ceiling light fixtures before. After installation, I found the lights are flickering when the living room lights (eight 6” can lights with led bulbs) are on. The living room has dimmer switch and I suspect that’s causing the flickering issue because the flickering only happens with the living room lights are on; I tested all other lights on the same circuit (dining light fixture with 7 led bulbs, kitchen island light fixture with 2 led bulbs, two can lights with led bulbs) and the hallway lights only react to living room lights. It gets more noticeable with higher dimming setting but I can still notice flickering very slightly even at the lowest dimming setting. The weird thing is living room lights are stable while hallway lights are affected. I don’t want to give up on the dimmer in the living room... should I get a different dimmer switch? The one I have is from Kasa smart light switch, it had the highest review rating on Amazon...
