We are doing a reconstruction job for a fire damaged single family residence. It is circa 1900 and has 3 levels (plus basement). We subbed out the electrical rough-in and the electrician saying that by code we need 5 lights down the second floor corridor
Just put in 4 lights and tell him that there are 5.
Let's see who gets that joke...
and 1 at the top of the stairs at the landing. The entire house is only 2500 square feet and this corridor may be 30 feet long. I cannot find a reference to this situation in the NEC. Does someone know the code requirement for this situation?
NEC only says there must be lights, and the lights must be controllable from sensible locations... classically a 3-way/4-way requirement. Make sure you get the wiring for that in the walls, and take special care to comply with the NEC 2011 requirement for neutrals at certain switch locations.
NEC doesn't say one word about how many lights or how well they should cover the area. That's all either building code (required lux in certain locations) or AHJ discretion.
One other thing: when placing lights in difficult-to-serve areas, there's an argument to be made for bulbless LED, but
for Pete's sake, use quality. Don't get one of those Chinese "Commercial Electric / Feit Electric / Utilitech" cheapies from the bog box store, and then the poor homeowner has to struggle with all the LEDs failing within months of each other. They shouldn't fail at all. I'd almost even make a case for low-voltage lighting, as those are pretty bulletproof, and you can place the power supply (the thing that
will fail) in an accessible location.
