Almost all the ceilings in my 1950 ranch have a hairline crack somewhere. Usually in the center of the room. My father-in-law patched the cracks in two rooms. We primed and painted and the cracks came back after about 1 month.
The ceilings are smooth plaster. The first layer is a drywall like material that comes in rectangular sheets. Then on top of that is a layer of essentially concrete and then a thin layer of white substance that is incredibly smooth.
His procedure for patching the cracks (as best I can tell) was to open the cracks. paint cracks with killz2 primer, fill cracks with joint compound, sand, joint compound, sand, joint compound. prime ceiling, paint.
On one of the ceilings he used tape, not sure if mesh or paper. Also not sure what point the tape hit the ceiling. Either way, both ceilings cracked. The one with tape looks worse because the tape stands out more than the hairline crack.
So my question is, what did we do wrong? We have 3 more ceilings to tackle and 3 chances to do better. I am not going back to fix the two ceilings any time soon, more important things to do.
Also, separate issue. There was some water damage to a section of ceiling, likely due to ice dams. I picked out the loose material and now there is about a 4" hole in the ceiling. Should I patch with drywall? I have several 5" cut outs from the recessed lights I put in. I could make the 4" hole a 5" and use one of my cut outs?
If you need pictures I will try to get some this week.
