1 - 12 of 12 Posts
Hello when would be a good time ti stsrt to scrape celing to get rid of all the peeling paint thats in the room. What could be the cause of this i just installed three vent on attic. Pic posted
Sent from my SM-G900V using Tapatalk
What type of vents, where and why? Attic vents work from low to high so need some of both.
Any exhaust fans being vented into the attic or at the soffits?
Bud
Charles, your short posts are not giving us enough information to help you.
1. Are you trying to vent the attic?
2. Why?
3. Is there any other ventilation up there, at the soffits, ridge, or gables?
4. You said ceiling, now you say walls?
Bud
Discussion Starter · #6 ·
Hello sorry i have a ridge vent two gables on either side of house i now installed vents. My house which is a ranch i saw bubbleing on the ceiling after guests left the house. The problem is with the celing sorry if i said walls
Ok, we're struggling but we are getting there.
Attics are often hot and that does not cause paint to peel. Moisture does, but that moisture would be coming from inside the house.
What state are you in so we can judge the climate?
Was the ceiling recently painted?
Can you get into the sttic to inspect the top side of the problem areas?
Bud
Also, is there an air conditioner up there?
· Registered User
Check Bud's post #9, you may find the ceiling insulation lacking in those spots allowing room moisture to condense there due to plaster temps reduced for condensation.
Gary
1 - 12 of 12 Posts
