Hi, as the title implies, I had to add extra wood to my framing in the basement. The plumber needed bigger pipe. They added another 2x3 on top of the current 2x3. When the plumber was done, I realized that I need too an extra 2" for the dryer exhaust. I added a 2x4 on top of what was already there. (see pic)
Now, I need to install cabinet, I have 2 sections, both weight (empty) 70lbs each.
The first layer of 2x3 won't go anywhere since it's stuck in the spray foam. My issue is with the 2nd layer that has been secured diagonally with screw. The final 2x4 are secured to the middle 2x3 section.
Should I try to reinforce using the 1st floor joist? I could probably attach the 2x4 row to a secured 2x4 between the joist.
Thank you!
Thank you!
