Our Grundfos MQ3-35C booster pump failed, and I ordered the same exact model thinking that a direct replacement would be pretty straightforward.
After receiving the new pump and looking at the connections, it looks more complicated than loosening and reconnecting threaded union connections at the inlet and outlet. A picture of the pump is attached.
The inlet plastic connector is threaded onto the pump on one side and threaded onto the copper pipe on the other. Looks to me like the connection must be made by threading the copper to the plastic, plastic to the pump, and then soldering the copper to copper.
The outlet connector has a union that is threaded onto the copper pipe on one side and fits into a union connection on the top of the pump.
What is the correct procedure for disconnecting the old pump and connecting the new one?
Thanks!
Thanks!
