1 - 20 of 31 Posts
I haven't seen much on this topic so I figured I'd ask. I recently painted my kitchen and am now getting around to the baseboard. Whoever installed the tile in the kitchen didn't remove the baseboard and instead just tiled up to it, not evenly either. It was pretty beat up so I tore out the base board and fixed the walls. Now I'm ready to put the baseboard back and I'd rather it look a little nicer.
Is it a problem if I fill the gap between the tile floor and drywall with grout to have a nice surface to rest the baseboard on? Should I put something between the new grout and drywall? I wouldn't think there would be an issue with just throwing grout in the gap (1/4" to 3/8" wide) but I figured I'd ask.
#1 That drywall was suppost to be about 1/2 up off the subfloor.
The gap between the tile and the bottom plate is there to keep the tile from "tenting".
Just set the base on top of the tiles, the 1/4 round will cover any small gaps or make up for an unlevel floor.
Reactions: JazMan
Drywall is 1/2" above the subfloor. Can't use 1/4 round due to floor layout/aesthetics. I don't think tenting will be an issue as the baseboard was grouted in when I removed it. Wall repairs built the wall out and the tiles weren't evenly spaced and now interfere with the baseboard.
Will try to take some pictures tomorrow.
Camera wasn't charged this morning and my phone couldn't seem to get a good picture, grrr.
I drew this up a few weeks ago
I went with option 2 since it would provide the most uniform look. Option 1 is basically how it was when I arrived but is no longer possible due to how some of the tiles are in relation to the wall (baseboard doesn't fit). This baseboard continues into other rooms without changing or having a good opportunity to put a transition in. This means the top of the baseboard has to be maintained, if it didn't, putting the quarter round or other shoe molding would look fine. Unfortunately not the case.
Not a good idea. First of all grout will not bond correctly with wood . Grout the tile first without base boards. After its all sealed and looking pretty, install your baseboards. Most people don't use or need anything between the two. But if you really wanted to, then use some caulk around the baseboards to make it look all nice and it will seal the crack between the two.
· Tileguy
Info2x,
Joe told you the right way to do this, both #1 & #2 are wrong and can someday become a total failure.
You should never grout between the tiles and wall or base moldings. Your floor is prime example of the necessity for shoe molding, especially if the base looks like the sketch. You can rip the new base to match the other room, or there's a way to transition the heights.
*note,
Sorry Gibsonc2, I can't agree with what you said except that it's "not a good idea".
Jaz
Discussion Starter · #8 ·
It's obvious that no one here thinks it's advisable to grout right up to the drywall, fair enough. I would think it would give long before tile but I'm no expert, hence why I'm here.
I wasn't grouting the wood into place. That is how it was originally though.
Info2x,
*note,
Jaz
Jaz Option 1 was how the floor was originally done and cannot be done today based on clearances so don't worry no plan on doing that one.
With respect to option 2 if there was a way to keep an air gap (or insert very soft material) between the grout and the drywall to absorb thermal expansion and whatnot would that be viable? I understand the shoe molding comments I really do, but to me it looks out of place given the already shortened height of the baseboard. That's the reason I'm trying to avoid it like the plauge. The vast majority of the grout would be hidden so if it cracks near the edge it probably won't be visible either.
Thanks.
· Tileguy
Gibson's comment about grout not sticking to the wood is not relevant. It's not supposed to and the job was done wrong the first time.
I know it was done like #1 the first time.
The width of the space you grouted looks to wide to do it the conventional way. The base should have been removed first and then the tiles installed. The last 1/4" or so should be air, or caulk. So how do you plan to cover that space between the tiles and the base? You need shoe. It'll look not only fine, but it'll be right. All hard floor coverings need shoe. Vinyl, hardwood, ceramic etc. The only time you do not use shoe is with carpeting.
Jaz
Discussion Starter · #10 ·
I haven't grouted anything. The only thing I have done here is remove the old baseboard that we all agree on was installed incorrectly (baseboards in place).
The gap between the existing tile and the dry wall is 1/4" to 1/2", my molding is 3/8" thick so I'm only looking for 3/16" to a 1/4" grout line if I don't go to the drywall completely.
I bought a piece of shoe molding and disagree, it didn't look right because the actual molding is significantly shorter than it is normally. I don't believe that shoe molding is required either, it's a choice.
Thanks
What does "actual molding" mean? Do you mean your baseboard?
Anyway, we're in the realm of "choice" or opinion and you came here to get it, so here it is.
Shoe molding is more or less required. Not in a technical sense, because there are no codes governing this - it's aesthetics. But at this point you're asking about aesthetics.
If you think it looks wrong, then you got the wrong baseboard or installed the baseboard too low (like option 1).
Shoe molding is not always "quarter round". In other words, there is unsymmetrical shoe molding. Normally it's installed tall side up, shown below. But I saw it in one house installed backwards - i.e. short side up. It looked kinda dumb, but no one looked real close and if the tall side up makes you think your baseboard looks too short, then install it short side up. Not great, but WAY better than your idea of leaving it out.
Discussion Starter · #12 ·
Sorry, I should have been clearer... actual molding in that case is the baseboard.
You're right we are into aesthetics where the line between right and wrong is as clear as mud, joy. I was aware of the non-quarter round shoe molding. I was using that as my comparison.
Ok let's change tact here... If I were to replace the baseboard with let's say a thicker piece or one that I didn't care about height and could have shoe molding such that the gap is covered how would one go about transitioning to another type of baseboard? The baseboard that I'm dealing with is cut down so it matches the height in the joining rooms (just about the entire first floor). There is no easy transition point that I can see due to the openness of my first floor.
Since I'd rather not have to replace all of the baseboard because someone mucked up one floor at some point I'm basically trying to cheat the system, I understand that. I also accept that there is a certain margin of risk in that as well.
If only the whoever put this floor in had just done it right or at the very least left a proper gap. :furious:
To transition, you have a couple choices. First photo shows a transition piece installed between the 2 types of baseboard. (In this picture the baseboard is the same, but you'd use the baseboard corner piece simply placed between the 2 baseboards).
Second photo shows a transition where you simply butt the baseboards together, but you trim up the side of the higher baseboard first. You cut the higher baseboard trim at a 45 degree angle, just like you were going around an outside corner, but you cut the second piece very very short. (This picture shows it going around a corner, but just ignore the corner.)
· Tileguy
I can't locate a picture of how to change height, but it's done with a few miters. Grab a piece of paper and I'm sure you'll figure it out. Or.......
You can change at a doorway by doing something like this;
Jaz
Discussion Starter · #16 ·
Ironically, no shoe molding there (or in my photo either) :)
I noticed that too. :whistling2:
Some interesting pictures for sure. Anything about making a transition mid wall? I have a few of those.
I've seen that done on a door way but unfortunately that isn't how either entrance to the kitchen is laid out. No real way to add casing.
Here is a shot of that side of the kitchen (These was taken before I bought the house and started to paint).
From that angle it looks like adding casing wouldn't be an issue, but here it is from another angle
As you can see the wall just meets at a corner so I can't put casing on that side. I think it would look kind of odd. Also the baseboard at the bottom of the wall would be different as that continues directly into the other room
It's sort of similar on the other side of the kitchen in that there is no casing location and the baseboard just goes out into the hall.
· Tileguy
Re; Lack of shoe in the pics we posted.
Not the same situation. In our pics the work was done in the correct order, floor installed then new base installed. In one case there is carpet on one side, in the other two cases the base is high-end and thick, which covers the required expansion space. Many people do not like to shoe, or don't wanna bother adding it cuz they installed regular base. But the shoe also helps if the floor is not perfectly flat.
That first pic looks like a perfect place to do a new decorative jamb and casing like in my pic. (pic #3). I don't get what you mean about your pic #2.
Changing at mid wall is done with miters, there must be a pic in some carpentry forum. It's done all the time when going from a living room to foyer where the foyer was installed with mud and so it's an inch or so higher.
Jaz
I was partly joking - note in my first pic there is actually shoe halfway in - see the corner.
Basically you can do it just like shown in the photo - turning the corner is irrelevant. You don't cut the big base flat off, you trim off the side of it as shown.
· Tileguy
Jeff,
I didn't mean your pic #2, I was talking about the OP's #2. What's his name anyway? (info2x from the great state of Michigan!). :thumbsup: Why don't people give a name? They'd rather be called R2D2? :laughing:
Jaz
Discussion Starter · #20 ·
Info2x is a name I've been using ever since I got onto the internet, just a habit I suppose.
Anyways... What I'm referring to in my second picture is the opening just ends into another wall, not going to do any casing on that side. I'll have to look for some pictures where the baseboard changes design mid wall which is what would happen where the floor changes from tile to carpet in picture 2 and on the opposite side of the fridge where it goes from tile to hardwood.
I understand the corner method and that gets me out of the casing scenario, just need to figure out the mid wall transition.
1 - 20 of 31 Posts
