Adding on to house and need to add circuits. Have a Square D QO Panel that has all of the Neutral/Ground screws occupied. Can I pigtail 3-4 grounds together and put the pigtail under one screw to free up Neutral screws, or can I put 2 wires under one screw? Or does Square D make and extension for the Neutral/Ground bar?
Also am adding a subpanel (60 amp), is 8-3 with ground sufficent for 60 amps?
Thanks!!
Thanks!!
