Im upgrading my service to 200 amp and need to run a copper wire from main panel to the nearest water pipe into the house which is about 50 ft away on the exterior wall of the house. This is in a singe dwelling home. What size of copper wire do i need to use to make code? I do have a natural gas pipe going in to the house about 20 feet away from panel that goes into the utility room where hot water tank is could i ground to that and in the utility room run a jumper from the gas line at the furnace to the hot and cold water lines instead of going the 50 feet to the water line. Thanks
