My set up is as follows:
1. I have a homeowners permit from the jurisdiction where the work is being completed.
2. My main panel is a standalone (outside) on a pole with a weather proof box. (birdhouse) (SQUARE D panel).
3. I am installing a sub-panel in a cabin approximately 125 feet away using a 100amp 2 pole breaker.
4. The feed to the sub-panel is ACWU 1/3 (2 hots, 1 neutral, 1 bare)
5. The Square D sub-panel has a main disconnect in it as well, so I will be removing the bonding screw.
My questions are in regards to the grounding and bonding and the application of CEC 2015.
1. From what I understand, I remove the bonding screw in the sub-panel. Correct?
2. The bare wire is attached to a grounding lug, on the grounding bar attached directly to the panel. Correct?
3. From my understanding, I do not require a grounding bar/plate at the sub panel. Correct?
- This is my only real question. As the wording in CEC 2015 is a bit confusing.
4. The neutral wire is attached directly to a lug on the neutral bar. Correct.
Thanks
trevor
Super Moderator
1. yes
2. yes
3. not sure I understand what you are asking.
4. yes
Please specify your location. cec - Canadian electrical or cec - California electrical code.
He should probably include the province/ city for you.
The Calif CEC is 2016. ACWU (ACWU90?) is not available here (to my knowledge.)
Discussion Starter #4 (Edited)
Added
1. yes
2. yes
- Does a sub panel at a detached building require a ground at the detached structure, if the sub-panel is grounded back to the main panel?
4. yes
Canadian Electrical Code 2015
Alberta, Canada
Super Moderator
Not sure about Alberta but in Ontario you have two options.
from ESA
It depends. The Code provides two options;
First, the sub service shall be grounded by connection to a ground electrode; or
Second, the sub service shall be bonded back to the main service with a bonding conductor run with the feeder conductors.
That means you can use a four wire feed and no ground rods or plate.
Or you can use a three wire feed and ground rods or plate.
