We are in the planning stages of changing our electrical panel to 200 amp service and I trying to plan around any potential issues.
Currently, our old box is only grounded using the home's copper water pipe.
I was going to install the rod close to our meter; however, that side of our yard is all concrete (small city lot, see photo).
I have read that the rod needs to be a minimum of 2' from the house which presents the issue.
1) Could I use conduit to reduce trip hazard and install the rod 2' out from the house?
2) I could run a grounding wire across the house and easily install grounding rod in yard on the other side; however, I haven't found if I need to increase beyond 6 gauge wire for a run of about 30'.
