1 - 18 of 18 Posts
· sweaty
I was reading Wiring a House by Rex Cauldwell. If my memory serves, he said to connect a wire from the hot water pipe to the cold water pipe right above the WH. That way, the pipes will be grounded if the WH is non-metallic or is being replaced. My rental house has this.
If I should do this in my own house, what parts do I need?
· Licensed Electrical Cont.
If I don't do it on a service up-grade, I won't pass the inspection.
Forgot about it once, had to go back.
I have NEVER had to do this nor was I ever asked.
It is not code required and serves very little purpose. The hot water pipes are bonded through sink and shower valves and other cross piping.
Lately, the water bonding is becoming less of an issue with all the new pex like stuff being installed.
It has never been a requirement in my area to jumper to the hot water. In a complete copper system, like Petey said, they will be tied together at several points.
· Banned
Usually I agree with Speedy, but not exactly in this case. I don't like the idea of relying on non-electrical equipment to perform an electrical job, like bonding. I don't see how a hot water line can really get solidly bonded if you don't intentionally do it. I mean, connections at fixtures are done with flexible hoses, and even if they are metallic, pipe dope or teflon tape is usually present at the actual interface points.
No, incidental bonding is no match for intentional bonding. And since the code specifies that continuity must be maintained around removable parts, well, a water heater is a removable part.
You don't bond every piece of copper together. You rely on the soldered coupling.
The handsets in the tub/shower still all are soldered together, arent they?
I have seen kitchen and lav sets that are tied together with flex pieces but not tub/shower valves.
In any case, the remodels I have seen lately have the piping all chopped up with non metallic pipe in between so the whole thing gets compromised.
· Banned
I suppose the tub set is one way. I still wouldn't rely on it, because it takes almost no extra time or energy to just jump it out.
I also wouldn't bother with a system that was all chopped up, like PVC or pex, but metallic braided flex hook-ups. But systems that are majority copper that can get energized at one end of the house and kill you at the other end, need to be bonded.
I am starting to lean the other way on this.
When the service neutral is lost, the piping carries current, which wouldn't happen if it wasn't bonded.
Malfunctions can kill you either way I guess.
· Wire Chewer
Speaking of bondage, for those that have all copper for drainage pipes (older homes) should those be bonded as well? It kind of makes sense to bond the cold/hot together at the heater, and it takes little to no effort to do, so I may go ahead and do it in my house.
1 - 18 of 18 Posts
