What you're talking about there is rote teaching brric... just follow the recipe exactly or get your fingers rapped, don't ask why and don't stop to understand why.
However if you actually want competent people, teaching separation is very worthwhile. Then you can teach combination as an exception to separation.
Having a separate grounding bus is a "best practice" even in a main panel. It does a number of things to help competent people; makes it easy to convert to a subpanel, and makes it easier to stick a clamp ammeter on the neutral-ground equipotential bond, and makes you realize the neutral-ground equipotential bond is actually a thing that matters and can be used artfully.
It also prepares them for wiring subpanels; i.e. you don't have to UN-teach them "glom everything on the bus".
The metal chassis of the panel is ground. So multiple ground bars simply ground via the hard metal-metal and screw-threads contact with the metal chassis. You are welcome to wire a redundant ground strap if you feel inspired.
Other important lessons are not to "runt off" the wires so short they can only reach the breaker/bar they're on now. Every circuit's hot *and neutral* should be able to reach any breaker in the panel; neutral because GFCI/AFCI. Having to rearrange breakers is very common; a bunch of things have specific positions they must be in - generator interlocks, surge suppressors, PV, MWBCs, etc.
Also make sure they know this is an exceptionally small panel and they should favor big ones.
