Just had a new dryer installed. It wouldn't heat but otherwise it worked. Tech says I have bad wiring. I get 120V on each leg but 0V between the legs. In my old home, I see the ground is on the neutral bar in the panel. Strange thing is that neutral and ground on the dryer are on the same terminal.
Not sure what I need to do. Thanks in advance.
