I am upgrading my panel and have a few questions on grounding.
So im putting in 2 ground rods at least 6' apart, do the rods have to be driven all the way below the surface of the dirt? I have the underground acorn type clamps for the wire.
also it has to be one continuious ground wire from the panel to 1 rod then to the other rod, correct?
If I am using #4 wire does it need to be in conduit or can it come out of the panel and go right to the rod? also does all the wire have to be striped or just striped where it makes contact with the grounding rod?
sorry for all the questions, I just want to make sure I do it right.
Thanks
Thanks
