I would like to make a railing similar to this:
https://www.homedit.com/stair-handrail/
But put 1/2" thick glass and use red oak.
I was planning on using a 1" to 2" thick board for the top and bottom, top acting as the rail as well.
Is there a guideline for how deep the groove should be? Does the height/width of the glass influence this?
If the glass will be 1/2" thick, do I have to make the top and bottom grooves larger to accomodate wood expansion? If so by how much?
My current thoughts for dimensions would roughly be:
Bottom board 5" x 1" x 8'
Two posts 3.5" x 3.5" x 3'
Top railing 2.5" x 2" x 8' (less thickness of posts)
Cut a groove in the middle of top and bottom at 0.5"x0.5" to slide glass in to.
Glass would run full length less an inch or so on each side.
Any tips, thoughts, and suggestions would be great as I am fairly new to wood working.
