Hello all!
I spent some time on this forum last year - got excellent help & advice with fixing the HVAC system in my house - which had been mostly removed by a tenant when the house was foreclosed.
At that time, I had cracked the books, passed the EPA test, bought two condensers, an evaporator and a furnace.
Put together the upstairs system, got the AC working. Then winter came, and AC became less interesting
and the whole project hit the back burner. In fact, my permit expired and I had to go get it extended. They only give one extension, so I better finish it up this year.
Putting together the downstairs system I will have to braze up the suction line to the evaporator. The evap is a Goodman 3030-something. I am worried about heat. The suction line disappears into the cabinet and there is insulation on it inside. I pried out the rubber grommet....
Does one remove the panel to get at the innards and shield the insulation etc? Or just stuff in a wet rag and braze away?
I have refined my procedures a bit since last year. Now I have a proper adapter for my nitrogen purge setup, consisting of a brass airbrush fitting ( 1/4 IPS on one end, and a little tiny hole at the other end ) - brazed to a piece of 3/8" line, and the other end swaged so it slips over the tubing that I'm brazing. And a 3/8" to 3/4" adapter that I brazed and swaged up out of scrap tubing. The tiny hole makes it easier to set a reasonable
flow rate that won't use up all my nitrogen.
I also got a little tiny welding torch - the kind the sell at Harbor Freight. This thing is so little and so light, it's like holding a welding pencil. Yet it brazes 3/4" tubing with sil-fos no problem. You have to be a little patient, but it does do it. And it's easy to get behind the tubing to the blind spot.
So if somebody could supply me with a clue as to how to braze up that
evap, I'd appreciate it....
- Jerryk1234
- Jerryk1234
