1 - 8 of 8 Posts
good morning all. i have been a home owner for three years now this is the first year i got a complament on my lawn saying it looks like a carpet. i want to make it greener its nice and full and thick just light in some areas whats a good fertilizer to use i use scotts 4 step program. just wanted to see if there was anything just to use for greener lawn.also another problem is when i use two sprinklers at one there is no pressure to run them bith so any ideas on what i can do to get enough pressure to run them both i dont mind not runnijg togethet its just i have to unplug one tjen con ect it to other.
Sent from my SM-G900V using Tapatalk
Cool season grasses go dormant when it gets hot. Lots of water is all you can do.
I don't understand the problem with the sprinklers. Turn one off, turn the other one on. Why do you have to unplug? Maybe you need another hose or a Y-adapter?
I have a simple shutoff valve on the end of my house. I can switch from my power washer to my sweeper nozzle to my sprinkler with a quick quarter turn. I never have to run back to the house and turn that spigot handle 100 times. I recommend it.
http://www.homedepot.com/p/Melnor-Metal-Hose-Shut-Off-395S/203136689
Ok, here is my setup for my front lawn.
I have 2 spike sprinklers on each corner in the front.
https://smile.amazon.com/gp/product/B00LORAFGM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
https://smile.amazon.com/gp/product/B0046734XS/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I run 2 separate hoses to them and have them on a timer. my water pressure is only good enough for 1 sprinkler at a time so I have them on seperate channels and one runs for its specified time then after about a minute of it being off the other one starts. no interaction needed from you once you set it up. This timer gives you 2 automatic valves and a third manual valve that you can use without having to unhook everything.
https://smile.amazon.com/gp/product/B004PVK4GK/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
1 - 8 of 8 Posts
