1 - 6 of 6 Posts
the guys who replaced a wall in the kitchen didn't clean off the ceiling wall. so near where they taped at the ceiling there is a grease spot that leaked right through the joint compound. I haven't yet painted because of this.
How do I go about fixing this problem so I could paint? I'm thinking if I sand it will just spread the grease around and when I get deep enough it will smear it into the dry wall. not to mention the sandpaper getting clogged up. anyone with experience and/or suggestions would be greatly appreciated.
Try some ammonia and water solution
Maybe half and half and if that doesn't work try ammonia straight out of the bottle. Another choice could be a all purpose cleaner called Simple Green.
You may have to apply a primer sealer to seal it in if you can't clean it up.
the primer sealer should be a oil base.
Hope this helps you with a plan of action.
Tired, Cold, and Damp
Any liquid cleaner will affect the water-based j/c
Though you'll have a teeny bit of wiggle room before it basically melts the repair
Clean it as much as possible (very, very, little)
Then seal it with a solvent-based sealer
And oil/alkyd may work, but to be sure I'd use a shellac/alcohol based sealer
Even if you were able to clean it, it would most likely continue to bleed through (after painting) if not properly sealed
I found that out earlier today; some joint compound easily came off the on the rag soaked with tsp that I was cleaning the spot with.
Excellent advice. Thank yous.
1 - 6 of 6 Posts
