1 - 2 of 2 Posts
I want to put the grate drain at the bottom of the steps where the blue square is located. The grate drain is 5 inches deep. My footer is 6 inches deep. I do not want to go under my footer. Can I notch out a part of the footer (yellow circle) to connect to the drain tile? Or will that cause a structural issue. The reason is water runs down the step during heavy rainfall. I am using 4 inch perforated pvc.
When you say 'notch out', do you mean 'go through'?
Are you tying into a drain tile on the other side of the footer?
It would not be advisable to punch through the footer, nor would it be possible without something like a core drill. ..and even then, if there is rebar.
1 - 2 of 2 Posts
