Heyo :jester: .... installed this granite vanity top stock from HD in the bathroom reno, as you can see in the description it is "sealed for added extra protection." I double checked with the dudes in the store (I know, I know..) too.
All installed, hooked everything up, and bathroom is now in use. I noticed that drops of water that splash up on the top from the sink, or a ring of condensation from a glass left on it will cause the spot under that splash or condensation to get "darker" (not really stain, because stain sounds permanent) if that water is left there for a bit (when I notice it a couple hours later). When I wipe away the excess water/condensate, the "dark spot" is there, but if I come back in an hour or so, its gone.
That's a good thing that its gone, but leads me to believe this isn't how it should be functioning, and is indicative of a need to seal it. Or maybe I'm wrong? Not too much experience with granite, so your thoughts on whether I should seal it again or not (or other opinions) would be greatly appreciated! :thumbsup:
Edit: one more thing, if you recommend sealer, maybe a specific product? I saw 2 on the shelf at HD, not a big selection, and price was high too!
