My advise is to find a pro to modify the opening. You only get one oopppss when cutting granite. But a 4" grinder with a diamond blade will cut it easily. Do not leave square corners with nicks. They should be smooth and rounded. or cracks can start there.
· Tileguy
Are you updating the cook-top?
If so...get a granite top manufacturer to come and cut the hole larger. You'll be glad you did maybe.
Cutting into granite takes more than just a grinder and a diamond blade. Holes may have to be drilled fist and someone may have to be able to read-the-stone first.:)
