Hi,
I have an existing second story deck over a concrete patio, which we want to waterproof and therefore need to add a grade to the deck surface for water run-off. The deck is approx 40x10.
The current thinking is that I can use screwjacks to support the deck while I cut approx 2" out of the support posts and then lower and reattach the support beam to the posts. I am worried about the effect this will have on the ledger board where the joists are attached, i.e. will the residual stresses have an effect?
Also, it doesn't look like the ledger board is attached using lag bolts or the like. How else would they have attached this back in 1998? Was it code then to use lag bolts or similar?
Thanks
Chris
Thanks
Chris
