I applied the pre emergent and I am told due to the cold weather in our area that it did not do its job so I look others have a yard full of crab grass. I have not been able to get any good input by googling on the web regarding which would be the best chemicals to use for this weed. It seems like the traditional Ortho and others are so watered down that repeat treatments are the order of the day. Does anybody have any success stories in this area. Thanks
crabgrass big time in Allen, Texas
Hey, rommel. Ken here with The Home Depot in the Chicago area.
Crabgrass is a problem all over the country. The chemicals being
watered down isn’t the problem. It’s the cold weather. The fluids in
the plant aren’t moving very fast. When it’s cold and you spray, the
chemical takes a long time to be translocated to the roots. Sometimes
it doesn’t get there. Once it gets warmer and the fluids are moving faster
you will get better control. Spray again when it’s warm.
Good luck and take care.
· Too Short? Cut it Again!
If you already have crabgrass a pre-emergent will have no effect whatsoever. You need a post-emergent herbicide now. Many of the best for crabgrass require an applicator license, permits and so forth so you may find it cheaper than wasting money on consumer products to call a turfgrass or lawn maintenance company with them to help you out.
