Many heat pumps do not come with low pressure or loss of charge switches. The problem is they continue to run empty which often times ruines the compressor. Yours has a leak, possibly full of contaminates and a bad compressor.
Time to replace the whole thing because repairs will be almost the same cost. Get 410A and avoid any future R22 hassels. Both will still be around long after the new system dies of old age but R22 might be mighty expensive in a few years. If the old 2.5 ton cooled well then you don't need a 3 ton unless you buy a 2 stage, they only come in whole numbers.
