Ok I am attempting to hopefully get some clues within the next 20 hours before I have to call a professional and cough up some money. I have already search here and found no answers. Search all over on the net and youtube but nothing.
I have a less than 3 year old Goodman GMH95 just yesterday it did not work. The only thing that is happening is it is humming. I am also getting a LED code 3.
Here's what I have checked. I have checked to make sure there is no clog on my intake/exhaust pipe (can't see all the way through). Main fuse unit is all good, small fuse inside furnace is still good. Outlet that plugs in is working properly. All wires seems to be connected tightly. Thermostat works find and clicks when I turn on the heat. When I turn on to make the fan on continuously the fan doesn't turn on. People keep saying find a red reset button but I cannot find one.
I am not knowledgeable in furnace some when people give out some parts name I wouldn't know what is what. If you do it would be helpful if you describe what and where on the furnace you are refering too.
Thank you in advance. I will keep messing with it for the next few hours. 8 degrees outside, yaaaaay!!!
