Ok, I'm not a expert but I've worked on my own furnace several times, so bear with me.
Goodman furnace GMH950704cxac, that is probably about 6 or 7 years old now does not seem to be getting gas.
Everything starts up normal, I can see the ignitor turn red hot, but there is no fire at all. Sequence repeats three times and then the board flashed one light which means lockout.
So I suspect it is a gas problem. I have a gas log set on the the same gas line and it works fine so I do not think there is a gas supply problem.
When I disconnect the plug to the gas value, there are three wires labeled M, C, IH. When I connect the C and M, I get nothing at any time. When I connect the C and IH, I get 24V for a brief moment at the very end of the ingnitor sequence.
That is one thing that seems very strange to me, I do not get the 24V until the ignitor is basically almost not red anymore. In fact the ignitor is almost off before it happens.
Also shouldn't I get the 24V at the C and M, as the M is the low. And the IH is the HI in the 2 stage?
I have a feeling I should be getting 24V at the low and that would mean a wire or board problem.
If I am wrong and I should be getting 24V at the Hi, then it's either trying to late or its a bad valve.
Any help would be greatly appreciated. My cranky wife would love to have heat again. lol
