1 - 20 of 25 Posts
How can I build AM radio antenna? They seem pretty straight forward but my problem is I have alot of metal on house and large metal shop. Metal interfers with radio signals so I have my tower set up 45' from closes metal which is also about 150' of wire run to my main home theater receiver. So I think it'll need boosting, which I aready have a HD & FM antenna with built in booster and rotates. Can signal be split on tower and receiver ends and use same booster set up? Also any ideas on antenna built would be helpful.
I will be watching your post for any ideas, because I generally only listen to AM, and have similar problems, so have tried several things over the years, with not much success. The problem that I have found is that it is a bit counter productive, because any time that I have increased reception for stations that I want to pick up, I have also increased reception for a few dozen more stations that I would not otherwise pick up, so while the clariity might go up, the clutter becomes worse.
This are suppose to be the Bomb
C Crane is suppose to be the bomb for AM radio's but, I've never used one, but according to their own words???? Have you ever tried to build a ferrite do it yourself antenna?
Retired Moderator
I changed your title--hope you don't mind---Mike----
Retired Moderator
Spell check doesn't work on titles----
Recent memory, no, but now you have me thinking. Growing up in the 60's, with an uncle who was an engineer on the Saturn V program, and a mom who was involved with some of the early LanSat photograpy development, I tinkered with about every electronic device that I could get my hands on, assembled a number of Heathkits, and built a lot more toys from scratch. At one point I had a fairly elaborate ham setup, with several antennas, both for ham and regula public broadcast. Don't hold your breath, as the odds are slim that it has survived numerous cleanups and throw outs, but I will take a look in the loft in the shop, and see what I have kicking around. Maybe, just maybe, there's a long forgotten soultion there.
If I remember correctly from my college days, the ideal antenna for a particular radio station would have a single element that would be equal to the length of one cycle of the broadcast frequency.
Without research, it my guess that an antenna for the AM broadcast would be 30/40 feet long!
Retired Moderator
I remember that from a boyscout manual---30 to 40 feet--horizontal---sounds familiar--
I found a calculator to find the wave length.
http://www.1728.org/freqwave.htm
A 1000 kHz frequency has a wave length of over 900 feet.
I believe that an antenna length that is an even fraction of this wave length can be effective.
I wonder if a ferrite core with 900 feet of wire wound around it, would make a good antenna.
Discussion Starter · #12 ·
Rusty Baker, I like. If you don't want a smartass answer, don't ask a dumbass question. I personally can't help myself if you ask ye shall receive.
Discussion Starter · #13 ·
For the cost of a ferrite antenna with 900 feet of copper wire you could buy your own AM radio station.
Discussion Starter · #14 ·
I wonder what would be a good length for a ferrite bar antenna? What would be negative effects of the 150' wire run to antenna? Could I use the coax that is already ran as AM signal wire as well? Would the use of the signal booster on the line be needed, I don't use it for FM are TV because FM reception is good and I get locals on satellite now. I'm going to try booster on FM and see just what I can catch, just haven't had time. Are there is any FM channels out there that carry AM talk shows.
JOATMON
There are a lot of factors to take into account.....when it comes to antenna's and signal propogation....it really is FM (freaking magic)
To some extent, your shop is actually a good thing....I would have put the antenna on top of it....the shop acts as a ground plane for better reception....ask any CB or ham operator.
AM is pretty low in the freq spectrum.....the impeadance of your coax as well as the freq response of your booster may not help you in the AM range.
Personally....if you have a radio with an AM antenna connection.....a good one is one of those round hoops.....looks like an 0 about 8" tall....4" wide.....they are typically shipped with AV recievers....
Discussion Starter · #16 ·
I had antenna on shop at one time and it would'nt catch channels 25 miles away, so I moved it after huricane Rita put a limb on it. The tower is about 20' of 2" cantlevered pipe thats about 4' in ground. I have a copper ground rod standing next to tower and hasn't sunk into ground after a year so I may need to apply some sort of physcal force seeing as gravity hasn't moved it.
Discussion Starter · #17 ·
Sometimes a picture is better then words. The real reason is for those of you that like to build are dream, the program I used to draw the pictures is call Googlesketchup and its free. I use it for anything from small projects to the plain I drew for my house build. You can do 3-D the first time you try it out. It would take 3 months of college classes before they would probably even start talking about 3-D. I'm not up on whats allow to be posted in here but just wanted to share. I will not gain a dime from the mentioning of product. Their are clubs for people that use this thing I'm not sure but from looking at their work I'd think they most be professionals. I could go on but all I can tell you is you want be disappointed. Heres the link http://www.diychatroom.com/members/jburd964-52894/albums/antenna-yard-layout-googlesketchup/
A Little Of Everything
A couple observations, and a confession...
Out of curiosity, JBURD, why are you after such a high-powered AM antenna? I know it's really none of my business, but it intrigues me.
Also, this thread has been populated by answers from the "50+ Crowd." :) Talk of HeathKits, etc. Man, I'm a kid in the 60s again! I'm hearing Boogie Check and Wolfman Jack on WLS Chicago - even though I lived almost 500 miles away.
Beyond that, I have absolutely nothing to add by way of advice. :)
Jack of all - master none
Although this does not directly answer the question, it is an alternative. I don't know what else you have in the building, but if it has internet access, just about every station (FM or AM) simulcasts to an online stream. No worry about antennas or reception, just hit the web-page and you're listening online.
1 - 20 of 25 Posts
