I'm replacing a handrail with returns at 120 degree angles. The originals show no nails and I'm not good with a hammer so would like to simply glue. The problem is that I'm not seeing a way to clamp the glue joint while it cures. The only flat surface on the handrail is the bottom. The only idea I have is to apply glue, push together and then clamp both to a third piece of flat wood. This could hold the two parts together but would not really provide a clamping force. Is there a better way? I would not mind building some kind of simple clamping fixture but am not sure what to do.
