Thankyou...I wish I had the right answer to your flooring question for you.I looked at the pictures of your property. It is so beautiful there!!
That is quite an undertaking!
In that case, I don't think you have too much to worry about. Laminate is typically laid down loose over a thin sheet of foam, and wood - usually a t & g product - is nailed down.Probably wood or laminate.
