1 - 20 of 159 Posts
· Administrator
We have partnered with ComfortUp to give away a SHARP 9,000 BTU Ductless Mini Split Heat Pump System 22 SEER.
To enter this drawing, respond to the following question.
How important is indoor air quality to you? Are you currently doing anything to improve it?
On June 28, 2016 we will do a random drawing from the responses in this thread to select the winner.
Added Note: Responses to this thread should be limited to entering the giveaway by responding to the posted question.
The Sharp 9,000 BTU Mini-Split Air Conditioner and Heat Pump System is wall mounted and features unique airflow control to provide heating and cooling for quick and easy comfort with a SEER rating up to 22.0. It includes Sharp's original Plasmacluster Ion Technology, an air purifying system that actively removes airborne mold and viruses, sanitizing the air in the entire space. Inverter technology on all models offers best in class efficiencies with a variety of finely controlled functions working to keep the room at desired comfortable temperatures.
Features & Benefits:
  • Multi Space Function - This function adjusts the airflow and air direction to reach the set temperature quickly in several rooms, and then circulates the air to maintain the temperature.
  • Inverter-Controlled Operation - This function enables quick-cooling operation while limiting fluctuations in temperature and reducing power consumption.
  • Full Power Mode - In this operational mode, the air conditioner works at maximum power to rapidly cool or heat the room.
  • Computerized Dry Mode Operation - The indoor fan motor and the compressor are controlled by the microcomputer to maintain room humidity without dropping the room temperature.
  • Auto & 3-Step Fan Speed Settings - The air conditioner can be set up with an automatic fan speed, or the user can choose from three manually set fan speeds (HIGH/LOW/SOFT)
  • Auto Restart Function - Following recovery from a power shutoff, the unit will automatically restart with the same settings as before the power was cut.
  • Auto Changeover - During Auto Mode operation, the unit will automatically switch between heating and cooling modes to maintain a comfortable room temperature.
  • Winter Cool Function - This function enables cooling operation during the winter season at outside temperatures as low as 14, or down to 5 (Great for Server Rooms & Indoor Gardens)
  • 5º F Auto Cutoff - To protect itself from damage due to freezing, the unit automatically stops when the outdoor temperature drops below 5º F.
Sponsored by: ComfortUp
Ductless mini split heat pump systems, air conditioners, heating & cooling, ETAC & PTAC, HVAC Parts & Accessories from LG, GREE and other top HVAC brands.
· Retired Moderator
Indoor air quality is very important to our health, especially if one has breathing problems. It is ironic because I have been researching this very thing this past week, because we want to prevent breathing problems. We also are in the process of finding another air conditioner.
I have a mild case of COPD along with Asthma, so I am very concerned with indoor air quality.
Right now I use frequent filter cleaning on my window unit AC's and use an oil filled electric heater for winter heat in bedroom.
Most years I have eight months of cooling and four months of heating.
RR :smile::smile:
· Administrator
Very Cool Cricket and Thank You ComfortUp!
Boy, that sure would be an upgrade for my house. Air quality is important to me and I've haven't done much of anything to improve it. A couple of window units is what I've been living with for years. They work okay until we get into the triple digits and then I'm wishing I had more. In fact today is the first time I fired them this year and was quickly reminded on just how LOUD they really are. :surprise:
· JUSTA MEMBER
I'm turning 62 soon and last week at my Doc's office they told me that I have the lungs of a 20 year old.
I just use fresh air in summer, and heated in winter, 9 months winter, 3 months summer.
That would be a great addition to my home.
ED
· Super Moderator
Indoor air quality is very important to me and my family because we have allergies and asthma problems.
Currently we have two 300sq. ft. hepa-filter air cleaners, one in each bedroom. Additionally, next month, we will be adding another bigger 500 sq. ft. one to the main living area.
I never even considered inside air quality. All I care about is, its cool in the summer and semi warm in the winter.
I guess I do add to the quality by regularly changing air filters. Of course my reason for doing it is to protect the air handler.
Indoor air quality is extremely important. Having a wife with allergies and two small children and the reality that we spend more time indoors than out, its critical to ensure that the air we breath insider our home is as clean as possible. We unfortunately can't control the outdoor air but we can at least to something to help indoors. Mold, bacteria, dust, chemicals, you name it are all going to get into our homes no matter what we do. Best we can do is try to find some way to filter all that stuff out of the air that circulates throughout our home with our HVAC system or we also have a separate filter when pollen is at its worst.
· Tileguy
I know indoor air can be much more polluted than outdoor air, therefore it is important to keep it as clean as possible.
We upgraded the original '76 system a few years ago although it still worked reasonably well. The new 96% efficient furnace and 15 seer AC is a good match for our northern climate. We have a 5" thick pleated filter which works well. I had the installation company wire the blower for "filter speed" which runs the fan at about 27% speed so it can filter the air all the time if I wish. This feature also blends the temps within our home since it's what is known as a quad. Three living levels plus a basement.
Quads are difficult to heat and cool to within just a few degrees of each level. Our lower living area was often a good 8 degrees cooler than the upstairs bedroom level. With this system we're within 3-4 degrees, this is much better.
This Sharp Mini Split system would be the perfect solution for this lower level during the heating season. The level contains a family room, powder room, walk in closet and my home office where I write this.
Good luck to all the entrants!
Jaz
Reactions: Admin
Indoor air is very important to me. It can either make my morning or break it ... Currently I am growing houseplants such as spider plants, pothos, and other stuff because it helps purify the air as I got lots of electronics.
1 - 20 of 159 Posts
