1 - 2 of 2 Posts
Outdoor GFCI circuit. This powers a transformer connected to a string of walkway lights mounted in a masonry knee wall that forms the front wall of a 40' long planter box, having a masonry fence wall as its other side. Planter was washed with hot road patch tar to waterproof the planter, which has a french drain about 3.5-3 feet down from the soil surface, over which is 8"-10" of gravel, over which is about a foot of soil, and is fully planted and has an automatic irrigation system. Transformer and GFCI are surface wall-mounted away from the planter area and not exposed to irrigation, but are in direct sunlight. We're in hot desert climate - Scottsdale, Arizona.
Transformer filed 2X in 3 years. GFCI periodically trips, but has allowed reset until this last time. GFCI will not reset (no "click").
How do I troubleshoot this situation? Thanks!
Master Electrician
Does the GFCI reset with the transformer unplugged? What is the rated wattage of the transformer and how many total watts are connected to it?
1 - 2 of 2 Posts
