Is it common after years of use for a gfci to trip when a load hits it? Do they get a nuisance trip easily when covered outlet is exposed to a lot of moisture in the air ? Maybe theres leakage in circuit ,if so how can I test for it?
Mine has a sump pump on it an now the moment it kicks in the gfci trips.Has worked fine for a few years.I dont have other things on the circuit to it .
Is there a possible leak in current or moisture in wiring causing trip?
I temporarily plugged it into a heavy duty extention cord thats not on a gfci to test it an it pumped fine .
It's on 12/2 15amp gfci.20amp on breaker.1/2 hp pump.[not sure the startup draw]
I'm gonna start with the gfci -replace ,but wanted to do some testing also.
Any info is appreciated.
