So, are the screw connectors on the sides of GFCI receptacles supposed to have the wires under them or are they only there to secure the push in from the rear. These screws are very difficult to get a 12g conductor safely under them.
I struggled with wrapping wire around those recessed screw heads until if finally dawned on me that the screw heads are not meant for a wrapped wire. Putting the wire in the holes in the back, and screwing down to tighten them is how you are supposed to connect the device. I had a 'Der' moment when it finally dawned on me.So, are the screw connectors on the sides of GFCI receptacles supposed to have the wires under them or are they only there to secure the push in from the rear. These screws are very difficult to get a 12g conductor safely under them.
Some switches are being built like that now (P&S rocker switches). I always seem to strip and bend the wires (out of years of habit) and then look to see that the bend is not required.I struggled with wrapping wire around those recessed screw heads until if finally dawned on me that the screw heads are not meant for a wrapped wire
Since I have used them on GFCIs, I prefer the pressure plate, wire in the hole, screw down method. Seems much more secure, plus it's easier. I pay a little extra for that on a receptacle or switch, but it's worth it to me.The wire slips behind the pressure plate, not under the screw.
Yeah the pressure plates are nice on the regular outlets too, but since the code requires Tamper Resistant outlets, I have yet to see TR outlets with the pressure plates. Maybe the Menards store that I go to just doesn't carry them or I am not looking in the right place.Since I have used them on GFCIs, I prefer the pressure plate, wire in the hole, screw down method. Seems much more secure, plus it's easier. I pay a little extra for that on a receptacle or switch, but it's worth it to me.
As opposed to a mean spirited joke?At least mine was light hearted joke.
