I can not use my electric smoker on a GFCI. IT always trips. Is that due to the concept of the wet wood on the element w/in the smoker? The smoker does not trip the breaker when on a drop cord from a regular outlet.
It means your smoker is going to electrocute you someday or the GFCI is bad.
Appliances function fine on modern working GFCIs, unless the appliance has a current leakage problem.
Plug it into another GFCI and see if the GFCI trips.
Semi-Pro Electro-Geek
Sounds like your smoker has a ground fault. Probably should get that taken care of. It's dangerous.
Electrical Contractor
Your smoker must be smoked .... :whistling2:
Super Moderator
Check for a loose connection at the receptacle.
I fiund one for a customer one time, wire not tight on the receptacle.
He only used the receptacle for his electric grill.
