New construction here (modular), I installed 3 track lights on 3 different pre-installed boxes in our living room, all of them switched on the same switch. The circuit to these lights also feed 3 exterior lights. Today was the first time that I've ever switched the breaker "off" to install the track lights.
After installing them I tried to switch the GFCI breaker back to "on" but it doesn't stay in the"on" position, it just goes to the middle reset position. After pulling it to "off" position and trying "on" again, it does the same thing.
The breaker has been "on" and we've used the exterior lights a few times with no problems, and it didn't rain today so I don't think moisture was a problem. I'm thinking maybe I installed the track lights wrong, but I paid close attention during install and it was very straight forward. Since the switch for the track lights and exterior lights is in the "off" position when I try to turn the breaker "on", shouldn't even faulty wiring for the track lights not be preventing the GFCI from turning "on"? Shouldn't it trip only when I switch the lights "on"? Does this mean the problem may be a faulty GFCI breaker?
Thanks for any guidance you can provide!
