I have a hot tub which has a 30amp and 20 amp gfci breaker located in sub panel. All have worked perfectly for over a year without any issue until yesterday when my 30 amp gfci tripped and would not reset. Went thru all the steps to isolate each component to determine which one was the issue. As it turns out no issues with components but had water in my conduit (schedule 40 grey) from sprinkler system leakage. I broke apart the conduit, drained all water out (15' run). I then took my compressor and blew air thru the line to dry it all out. Came out this AM and breaker still will not reset (12 hrs later). Obviously there is a nick in casing in one of the wires I pulled (all 6 wires are shielded). Do I need to pull wire out and replace? Or push more air thru the line with say a shop vac? I would of thought that draining line and running compressed air thru line would have dried it out enough to stop any short. Any suggestions as to my next step? I really did not water to start over and rewire with new but that's an option.
Thanks,
Casey
Thanks,
Casey
