I installed 2 new coach lamps outside, next to the fancy new door I installed along with relocated the old GFCI receptacle off the kitchen onto the deck. :thumbsup:
In the past, there was just an outdoor receptacle with a GFCI installed.
I cut the wire for the old receptacle at a junction box in the basement as where the old receptacle was would be in the way, the circuit breaker was turned off....fast forward to today and I have done the following;
2 new coach lamps, with a single pole switch inside the kitchen.
power runs from the existing wire that was used for the old receptacle, into the new GFCI box. connection made to the GFCi, then off to the light switch and then to the lamps.
I turned on the power and the circuit breaker tripped.
I tried to reset the GFCI but the switch is stiff.
When I connected the leads to the GFCI, the load going into the GFCI and line coming out to the light switch are both connected at the GFCI.
Does the load go into the GFCI first, then come out to the lights?
If so, how do I do that, pigtails?
Also, the wire coming from the panel is 14ga the wire connectiing the new parts is 12 ga as that is what I had handy.
Thanks, Terry
Thanks, Terry
