Sorry this is pretty complicated. The point of my question is what to do with the grounded conductors.
I want to run 12/2 to a J box behind a sill, a switch loop to a switch/receptacle (because my wife doesn’t want to lose the receptacle I was going to take for a switch) using 12/3 and then pipe through the sill and to a wall mounted box outside which has a gfci receptacle. Then pipe runs up to a light device.
I was going to splice the hot from the home run to THWN going through the pipe to the line side of the gfci. From the load side I was going to run power back to the J box, splice with the switch loop and then to THWN back outside going to the light, keeping everything ground fault protected. Does this switch/receptacle grounded conductor need to be spliced after the load side of the gfci or can I splice it in the J box before it goes out to the gfci?
Thank you,
Ed
Thank you,
Ed
