1 - 6 of 6 Posts
I am close to ready for my rough in inspection for electricity on my remote mountain property.
I do not know electrical code well enough, especially NEC 2011. I am worried that I will have to pay for another inspection if I am not well prepared.
I have had the trench, and ground rods (2) inspected and passed. The meter box and transformer are in place and wire run from the trench to the workshop.
I have 2 GFCI 20 amp breakers, and plenty of 20 amp GFCI outlets. The lighting circuits are 15 amp and not GFCI.
I have 220volt tools (air compressor, radial saw)20amp, and a 50amp arc welder. I have never seen a 220volt GFCI circuit breaker. I have separate breakers for each of the tools.
Do I need GFCI 220volt breakers and a GFCI 15amp breaker for the lighting?
Lic Electrical Inspector
Not needed.
Is this building a garage? Separate from a home on the property?
Discussion Starter #4
It is a garage, separate from the house that burned down prior to my purchase. It will not be used as a garage but a workshop/breakroom. It is 70ft from the transformer and 80ft from the building site. I will convert the old basement into a garage and build the new abode adjacent to the future garage.
Super Moderator
You do not need both gfci breakers and receptacles for the 120v.
You could use one or the other.
Discussion Starter #6
I have the two 110v 20amp GFCI breakers on circuits with 3 regular 2-outlet fixtures each. These are for breakroom appliances (coffee pot, microwave, toaster oven, crockpot, and food processor)
I have separate 110v 20amp GFCI outlets as the first outlet only on circuits with only 1 regular 2-outlet fixture each. These are for electric tools.
I have a separate 110v 20amp circuit with a GFCI outlet for the refrigerator.
Does this sound OK?
1 - 6 of 6 Posts
