Hi,
I have attached an images of my jacuzzi tub, which leaks from inside. Whenever I turn on hot or cold water on the tub, it makes a sound inside the tub of water coming out, but nothing comes out at the spout. Instead, it leaks all over through my ceiling on my first floor, all the way to the basement! I'm pretty sure it's the mixer or the some connection to the spout that has burst, because the house was frozen before.
What's the best way to tackle something like this? The stone panel is made of plastic, NOT veneer rock. The rocks are just hollow plastic, when I tap it I can tell, and it feels like painted PVC. I was thinking of taking a diamond blade on an angle grinder and cutting through both the panel and the cement board. It's probably glued with mortar. I don't even know what the best way to approach this is, as I usually just cut out the drywall from behind a normal bathtub and put an access panel back in! If I wanted to do an access panel in this situation, how would you guys do that?
Thanks,
Mike
Thanks,
Mike
