My house has a 200 amp service panel with two 100 amp breakers which feed two remote sub panels.
Cables, 2 hots and neutral, from one of the 100 amp breakers on the service panel, and feeding one of the sub panels, are routed through a 200A dual throw transfer switch (adjacent to the service panel outside the house). The other side of the transfer switch is powered by a generator. fwiw, the generator is only 17kW
This works fine, but only feeds half the house!!
What is the "best" way, (safe, complies to code, most cost effective) to connect the second remote sub panel to the generator?
Do I need to add another 100 amp transfer switch, and connect the generator feed to both? Any issues with the neutral I should be careful of?
Thanks for any advice.
