My generator subpanel was installed with the help of an electrician years ago. He attached the both the white and green wires from the subpanel to the neutral bar in the load center. I remember asking him about this and him mentioning that neutral and ground both go to the same place anyway, and that it was only important that they be separate in the subpanel, which they are.
Well, I've learned more since then, and discovered that my load center has an isolated neutral bar, it is not tied to the ground bar. WHY? I wondered, then it dawned on me. There is no main breaker in my load center, the main breaker is actually beside the meter (50 feet away). Therefore, my load center is not the "main panel", it is technically a subpanel. Therefore my generator panel is a subpanel of a subpanel.
With this new knowledge, I assume it is not okay to connect the ground from the subpanel to the neutral bar in the load center, because doing so ties neutral/ground together, in a slightly indirect way. I have moved the green wire to the ground bar.
Does that sound like a correct fix? What bad things could have happened if I hadn't fixed this? With this configuration (Subpanel running off subpanel) what other issues/potential problems should I be aware of?
